Tip on getting my Neuspeed Strut bar?
Old Apr 4, 2005 | 07:38 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default Tip on getting my Neuspeed Strut bar?
I have a 1991 Civic Si and just purchased a Neuspeed front upper strut bar. Took off the Ebay crap strut bar that came on there and went to fit the bar over the strut bolts and got the driver's side on (as per instructions) and then went to try to get the passenger side on and the bar is about 1" too long.
Any ideas? Would jacking up the car help? Any helpful insights would be great! WHen I did this on my 1993 Civic it wasn't a problem and just dropped right on.
Autocross Help Page
Old Apr 5, 2005 | 12:34 PM
jaje's Avatar
jaje
HC Racer H5
i don't know...but it sounds like it won't fit as they should drop right in - is it a fixed position and you can't adjust it?
Old Apr 6, 2005 | 01:48 AM
jc836's Avatar
jc836
The 1" is the problem. Are you sure you have the correct one? If it is then jacking only one side will not help you. Pick up the car under the center front and let the suspension droop-this may cause the towers to spread a little.
Old Apr 6, 2005 | 04:18 AM
wilsel's Avatar
wilsel
Sounds like you got the wrong one to me
Old Apr 6, 2005 | 12:09 PM
CivicSiRacer
Well I did just jack up the front of the car in the center. It was just enough to get the bar on So it was the right bar, but I'm guessing this car was hit on one side which is why camber on the front is -3.5 on one side and -2.5 on the other.
These cars must have a pretty flexible chassis
The only stupid thing I did was jack up the car TOO high. The struts fell out of the holes So let me tell you it was fun trying to get the struts and bolts in their perspective holes on both sides with just one person
Autocross Help Page
Old Apr 6, 2005 | 03:54 PM
jaje's Avatar
jaje
HC Racer H5
at first i was why did the struts fall out as they should never do that...but then remembered you have to remove the strut bolts to put on the bar!
Old Apr 7, 2005 | 07:12 AM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
my nuespeed strut bar was about an inch too long, i put it on the passenger side and the pushed it tward the passengers side to get it on teh driver side
Old Apr 7, 2005 | 09:58 AM
CivicSiRacer
I tried that but I'm not a huge guy So I thought by jacking up the front it would release some weight off the strut towers enough to get it on Phyiscs my Dear Watson
Autocross Help Page
Old Apr 9, 2005 | 05:58 AM
jc836's Avatar
jc836
If you are dropped then the numbers would be closer to -2.5 on BOTH sides. THis could be higher or lower depending on the drop. Our race setup was about that initially and within 0.2 from side to side.
You are way out of spec and the difference is large-I would suggest that you put the car on a frame machine to be absolutely certain. It is not cheap but will help pinpoint the reason. Another thing is that you could well have a bent control arm or the bracket location (frame machine for the latter) is off.
