Stering Wheel
Old Feb 12, 2005 | 07:19 AM
gingas's Avatar
gingas
Default Stering Wheel
Here's my question, went pass junkyard other day, saw a 93 INTEGRA LS manual, steering wheel looked good, just need to clean wheel. Asked guy how much, told me $25. Would this fit onto my 91 Civic Si & if so what size socket do I need or would you just leave the OEM SI wheel on. I have a red H sticker in the center of steering wheel. Made my own red JDM H look. The TEG wheel does look nice, leather feels nice. Gingas
Old Feb 12, 2005 | 09:51 AM
Exempt's Avatar
Exempt
2 tone Rex
Im pretty sure it will work, as long as it not an SRS (air bag) version... Not sure if the 93 LS's came with air bags or not... But I doubt they did... As for the bolt, ud just use your stock bolt, cuz the only thing that changes is the wheel itself, not the threaded collum (sp?) which has the bolt that holds the wheel on...
Old Feb 12, 2005 | 11:11 AM
Kai's Avatar
Kai
Rotorphile.
The spline count is the same, so it would fit on. The only problem you might have is the clearance, it might stick out too far or not far enough.
90-93's had dual automatic seatbelts instead of a single airbag.
Old Feb 13, 2005 | 05:51 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Almost anything an Integra has that same year will usually fit civic.
