1st gen crx carb emissions removal
Stupid Hurts
i was wondering if any of you knew how to take all that vacuum crap off a 1st gen crx... ive heard you can do it and it doesnt really harm emissions?? personally i think it would make for a better looking engine. any suggestions would be greatly appreciated.
GWAKS- Tech Geekifier
Doesn't really hurt emissions, helps very mildly on engine performance, and doesn't hurt fuel economy one bit. It does, however, make the engine a lot easier to work on.
Here are some pics that should let you see what needs plugged, and what vacuum items still need to be hooked up to keep the engine running properly.
http://linus.highpoint.edu/~hleach/c...b/MVC-089F.JPG
http://linus.highpoint.edu/~hleach/c...b/MVC-090F.JPG
http://linus.highpoint.edu/~hleach/c...b/MVC-091F.JPG
http://linus.highpoint.edu/~hleach/c...b/MVC-092F.JPG
The line with the metal tube goes over to the charcoal canister just because it's a little cleaner than just letting that port vent to atmosphere.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Automotive Enthusiast
I've been working (slowly and lazily) on an article about this. Here it is so far: http://www.bay-town.com/members/tanvan/emission.html
Stupid Hurts
here for engine pix folder
or i could just post them here if thats easier, but they are bmp files yea my digital sux but for $30 o well right??
i havent touched anything yet... but i was figurein i could get a few opinions on this mess
basically hook up the lines like you see in my pics and then remove all the other lines and control boxes. plug anything that looks like an open port on the carb, and then drive the car to make sure there isn't any funny behavior.
Stupid Hurts
will i have any real problems if i do this?? ive heard of a few things on other boards but theyve also removed choke linkage and etc stuff all i wanna do is strip vac lines...?
shouldn't have any problems, when I did it I just removed vacuum lines, the choke didn't really work anyways, the only thing is if you don't have the secondary vacuum stuff hooked correctly you suck the float bowl dry and it won't accelerate above 3500 RPM. If you get everything right, it'll behave just fine.
Stupid Hurts
ok im convinced to try it, ill start with a few hoses at a time.. do i need anything outta the 2 boxes and can i disconnect all the metal hoses in the rear??
