problem...help
Old Nov 13, 2004 | 02:01 PM
Lm546's Avatar
Lm546
Default problem...help
My car is missing under acceleration, I cant figure it out. I have replaced cap, rotor, plugs,wires, and my coil. I have a ignition control module but if I put it on I cant take it back. My timing is perfect. If anyone has had this problem and has fixed it, how did you fix it? or if anyone knows how or has any info. please help. thanks is advance
Old Nov 13, 2004 | 04:05 PM
bullmtnbiker's Avatar
bullmtnbiker
Clogged injector or fuel filter? Probably try running some Techron fuel injector cleaner in your system.
Old Nov 13, 2004 | 04:43 PM
Lm546's Avatar
Lm546
this has been going on for awhile, it started after i used fuel injector cleaner. i checked all injectors, replaced fuel pump and filter. i have replaced damn near everything. i know its electrical but i dont know what
Old Nov 14, 2004 | 11:24 AM
Lm546's Avatar
Lm546
anybody?
Old Nov 14, 2004 | 12:53 PM
dubcac's Avatar
dubcac
I
Maybe the distributor itself is going bad? Have you tried resetting the ECU, or using a known good ECU?
Old Nov 14, 2004 | 04:52 PM
Lm546's Avatar
Lm546
nobody i know has a crx or any parts, so im pretty much stuck. if i want to check that stuff i will have to buy it
Old Nov 14, 2004 | 10:19 PM
augy's Avatar
augy
How did you go about checking your injectors?
Old Nov 15, 2004 | 03:49 PM
Lm546's Avatar
Lm546
i checked the resisitance on each injecotr, and i pulled them out and zip-tied them to the fuel rail and turned the key so they would spray to see if any of them were clogged, but all of them sprayed fine.
Old Nov 15, 2004 | 04:07 PM
Tankard's Avatar
Tankard
It could be the idle air control valve is sticking.
Old Nov 19, 2004 | 09:47 PM
crxresurrect's Avatar
crxresurrect
what kind of car, year, what kind of motor, what ecu(obd0,1,2)and is it throwing any codes that you know of. I am having a problem like that and a guy told me it could be the valves needing adjustment. Also could be on the intake manifold too. He wasn't for sure without looking at.
