Window removal
Old Nov 12, 2004 | 04:52 PM
crx87si's Avatar
crx87si
Durkedurkistan
Default Window removal
I found a window for the X at the local pull-a-part. How do I remove the driver's side rear window?
Old Nov 13, 2004 | 08:45 AM
crx87si's Avatar
crx87si
Durkedurkistan
Well the search continues, I popped the window while removing it.
Old Nov 13, 2004 | 12:27 PM
menappi's Avatar
menappi
take off the door panel and it should be self explanatory
Old Nov 13, 2004 | 02:10 PM
crx87si's Avatar
crx87si
Durkedurkistan
It's not the door window, it's the one behind it I'm trying to get.
Old Nov 13, 2004 | 04:18 PM
Kai's Avatar
Kai
Rotorphile.
They are probably glued in... you need a bit of luck to get those windows out.
Old Nov 17, 2004 | 06:40 PM
crx87si's Avatar
crx87si
Durkedurkistan
Well I may have found a yard close to here that will remove it for me.
Old Nov 18, 2004 | 01:18 PM
menappi's Avatar
menappi
ohhh.pop off the weatherstripping, and ull see a buncha of clips. break the clips. and then i gueses just pry it off. it should be stuck on there with some window adhesive type stuff.
Old Nov 19, 2004 | 05:26 PM
crx87si's Avatar
crx87si
Durkedurkistan
Yeah I did all that. The glass broke while trying to remove the glue.
