Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   CRX & Pre 92 Civic (https://www.honda-acura.net/forums/crx-and-pre-92-civic-8/)
-   -   differences between Si and other CRX's (https://www.honda-acura.net/forums/crx-and-pre-92-civic/16393-differences-between-si-and-other-crxs.html)
ISP James Aug 17, 2002 07:02 PM
im considering a CRX buy what are the benefits of getting an Si over a base CRX (motor aint no thang i gotta b18a1 waitin in my garage - actually a whole 90 ls integra parts car)
jc836 Aug 18, 2002 03:45 AM
Since you are going to do a swap you might as well find a clean HF as it is the lightest of the 3. If you plan to race ITA then the Si with its 1.6 is the way to go.
excitid Aug 18, 2002 05:46 AM
90-91 si has rear disk brakes, 88 hf is the lightest of all 2nd gen rexes. Do a search I believe we covered this topic recently
jdblack1 Aug 18, 2002 06:13 AM
the 88-89 Si's don't have rear disk but if that teg does you can swap it. if you get an HF you need to get bigger front knuckles for larger axles. JaJe knows more on the hf's. the 88 Si has pillar mounted seatbelts, it's the lighest weight of the 2nd gen Si's and it has a different rear suspension that is prefered by some.
ISP James Aug 18, 2002 04:41 PM
thanks guys if i need anything else, ill try a search or post more specific questions.
WhiteRice Aug 18, 2002 06:54 PM
I don't think rear discs are all they are cracked up to be. Don't get me wrong, they are definately better then drums, but not by much.
If you got a car w/out rear disc's or even with for that matter, get the big brake conversion. I think it's funny to see people wasting $$ on swapping rear discs when they could spend almost the same amount on a big brake and that'll help tons more.
But shoot, since you got that integra for a parts car, your set!!!! G'luck!! :D
ISP James Aug 19, 2002 06:30 PM
muchos gracias guys but one more thing.... did any CRX come with power windows or power locks??? i know its a small 2 door car but damn im lazzzzy!!!!
WhiteRice Aug 19, 2002 06:41 PM
Only the JDM's came w/pwr windows...not sure about locks though. My bro's CRX has the JDM Power windows. Here's the link as to how it was done. He actually bought the car off a guy who did the work.
http://www.thezcresource.com/html/pwrwindows.html
ISP James Aug 19, 2002 06:46 PM
thanks, ill definitly have to utilize that link.... now its on to findin a rust-less CRX around here....
ISP James Aug 19, 2002 07:12 PM
oh yeah any suggestions/recommendations on shift linkage to get that b18a into it???
© 2026 MH Sub I, LLC dba Internet Brands
