crx hybrid
Old Nov 4, 2004 | 03:03 PM
jake1511's Avatar
jake1511
Default crx hybrid
is there a way to swap a newer engine/tranny/ecu into a crx?
id like to try to do a b18b swap into a crx
what should i replace to make this swap work(if its possible)
kthxnp
Old Nov 4, 2004 | 05:42 PM
ManoloCRX's Avatar
ManoloCRX
All Motor
which ecu?
Old Nov 4, 2004 | 05:45 PM
jake1511's Avatar
jake1511
probably the one that goes with the b18b swap.
obd1?
Old Nov 4, 2004 | 06:14 PM
jlicrx's Avatar
jlicrx
kthxnp
yes, it can be done - the B18B engine is OBD2 which means a little more work - i would suggest the B18A1 which is available in either OBD0 or OBD1 - how much work is involved and what you need will depend a lot on the model of your CRX - Si being easiest - in any case, you will need engine, transmission, axles, shift linkage, ECU and a mount kit as a minimum
Old Nov 5, 2004 | 06:55 AM
jake1511's Avatar
jake1511
ok thanks
Old Nov 6, 2004 | 04:12 PM
ajusaf's Avatar
ajusaf
i have a dx 90 what will be tge easiest a zc engine? ecu and whatelse would i have to change?
Old Nov 6, 2004 | 04:22 PM
Kai's Avatar
Kai
Rotorphile.
The B18B1 is availible as an OBD-1 from a 94-95 Integra.
Rework it to OBD-0 using 90-91 B18A parts.
Swap it in like any other B.
