CRX starting problems
Old Oct 19, 2004 | 10:09 PM
Reason's Avatar
Reason
Default CRX starting problems
I know my timing is off, I havent had time to fix it or the money right now. I turn the key it cranks, I have lights and gas is pumping. If I hold the key half way it stays running. I can rev it and all, when I let go of the key it stops. Is it because of moisture? I sprayed all the wires under the hood and still nothing. My Subaru is having bodywork done, and I need my CRX for work. Can anyone help me out? Ill try anything to get this B***H started.
Old Oct 19, 2004 | 10:21 PM
v8guy's Avatar
v8guy
Professor
Is this what you are doing, you turn the key till it cranks, then once the engine catches and fires you back off a little so the starter stops turning and the engine stays running. If you let go of the key it dies? If so it sounds like a bad ignition switch to me. I've never changed one in a Honda so I can't help you there but what I'm talking about is the actual switch, not the ignition lock itself. When you turn the key in the lock it activates a switch, and I think the switch is what is bad. Hope this helps.
Old Oct 20, 2004 | 01:40 AM
Reason's Avatar
Reason
Yea thats what happens. Crap..I was hoping I didnt have to buy anything. Is this an exspensive part? are ignition switches an esay DIY? or Id be better off dropping it off at Honda?
Old Oct 20, 2004 | 11:04 AM
Pete's Avatar
Pete
Civilian
Honda will rape you even for little jobs. My suggestion is buy a Haynes Manual and do it yourself. Shouldn't be very difficult.
Old Oct 20, 2004 | 11:14 AM
Reason's Avatar
Reason
Alright, ill see what I can. Ill let u guys know whats up.
Old Oct 22, 2004 | 12:17 PM
B20powered's Avatar
B20powered
You can't see me
Don't get a haynes manual get a helms. Haynes are useless.
Old Oct 23, 2004 | 01:04 AM
Reason's Avatar
Reason
Could it be that my timing belt jumped a tooth or two? Ill check it when I have time this weekend.
Old Oct 23, 2004 | 07:30 AM
B20powered's Avatar
B20powered
You can't see me
Maybe, just get a timing light and check it youll know right away.
Old Oct 24, 2004 | 07:37 AM
Reason's Avatar
Reason
where can i get one of those? and how would i use it if my car dont stay started?
