bleeding breaks
Old Oct 17, 2004 | 03:18 PM
b16hatch90's Avatar
b16hatch90
Default bleeding breaks
hey can anyone indepthly explain how to bleed the rear drums on a 90 civic dx or send me a website that does explain it. thank you
Old Oct 17, 2004 | 04:37 PM
Kai's Avatar
Kai
Rotorphile.
Easy.
Tools needed:
8mm or 5/16" wrench (they are the exact same size, no worries)
vinyl hose, 24-36 inches, sized to fit over the bleeder screw's nub
glass jar
brake fluid
an 8mm deep socket is nice to have if the screws are frozen.
Loosen rear lug nuts, raise the car, and securely support it on jack stands. Pull wheels.
Starting on the passenger's side, attach the vinyl hose over the nipple on the bleeder screw. Fill the glass jar with a bit of brake fluid, enough to submerge the other end of the hose. Have a faithful assistant sit in the car, and make sure your master cylinder is full of fluid. Then follow the basic procedure:
1) Have your assistant push the brake pedal and HOLD IT DOWN.
2) Loosen the bleeder screw a quarter to half turn, until you see brake fuild and air bubbles flow into the hose and then stop.
3) Retighten the bleeder screw.
4) Have your assistant let the brake pedal back up.
Repeat the four steps until the fluid is clear (very lightly yellow tinted) and free of bubbles. Move to the other side and repeat. Make abolutely sure not to run out of fluid in the master cylinder reserve tank.
The proper order to do it on most US cars is the passenger's rear, driver's rear, passenger's front, driver's front. It is the order of the longest to shortest brake lines.
Enjoy.
Old Oct 17, 2004 | 07:03 PM
Mackenzie C's Avatar
Mackenzie C
nice, i think alot of people could use this
Old Oct 20, 2004 | 09:45 AM
mullinator's Avatar
mullinator
http://www.speedbleeder.com/install.htm
Remember to avoid going gorilla on the bleed screw when you're done. It doesn't take much force to make a good seal. The folks at Mity-Vac recommend 4.3 ft lbs. -scott
