single most effective mod you've done.
Old Aug 14, 2002 | 09:52 AM
excitid's Avatar
excitid
Default single most effective mod you've done.
What 1 mod have you done that made you the happiest that you would recommend to others. Please state the company name and price if possible.
Old Aug 14, 2002 | 10:34 AM
jaje's Avatar
jaje
HC Racer H5
the most effective serious mod i've ever done
gut the car...losing 200 lbs makes the car more responsive in any category...it is the single most effective and cheapest (free ) way to improve performance in all aspects
Old Aug 14, 2002 | 10:37 AM
WhiteRice's Avatar
WhiteRice
I'd say the ZC swap was the most effective for power, but I guess you're looking for like I/H/E or something like that....Then....the Neuspeed front sway bar for $80 is the best money I spent. It helps in every aspect or damn near of driving, daily and otherwise. :thumbup: :thumbup:
Old Aug 14, 2002 | 12:31 PM
Kirby's Avatar
Kirby
:werd:
Old Aug 14, 2002 | 01:25 PM
ronaldmcdonald's Avatar
ronaldmcdonald
Wow, you took out 200 lbs, and it cost nothing?! What did you do? I think I took out about 100 lbs off my '89 CRX Si by taking out most of the plastic interior panels, the carpets, some of the tar (still working on it at a slow pace). Is there other stuff you can do without spending $$$ or having a lot of mechanical skills?
I'd also like to remove the A/C and motorized sunroof, but I'm not sure how big a deal that is.
So far, weight reduction also happens to be my most effective mod, but that's only because it's the only mod I have so far.
I'm waiting on a set of TE-37's, but that doesn't count since it's not on my car yet.
Old Aug 14, 2002 | 02:32 PM
jaje's Avatar
jaje
HC Racer H5
the 200lbs is an estimate...but about 50lbs for a whole a/c system remove (lines, compressor, compressor bracket, evaporator, electrical switch)...then i removed the entire interior including radio/speakers...also when i swapped out the old d16b6 (hf engine) for the si i also removed several meters of wiring for a previous alarm system and a/c system...also under the dash i removed lots of other wiring that wasn't needed...the spare & jack were also removed
Old Aug 14, 2002 | 04:33 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Suspension Techniques Rear 22mm Anti-Sway Bar. My car now handles perfectly neutral.
Old Aug 14, 2002 | 05:14 PM
WhiteRice's Avatar
WhiteRice
How much did this run ya?
Old Aug 17, 2002 | 10:35 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
Shocked no one said "Engine swap"
Old Aug 18, 2002 | 06:02 AM
jdblack1's Avatar
jdblack1
is that a single mod
