getting close
Old Aug 30, 2004 | 11:42 AM
ED9man's Avatar
ED9man
driver
Default getting close
i'm getting very close to ordering my swap and I need to know what micellaneous parts I need to order from Honda. I know that I need a 2g Integra throtle cable, and radiator hoses. Can someone give me the specifics as to what exactly I need. I have an '88 CRX Si. Getting a first gen B16a complete changeover from hmotors along with mount kit, linkage, LSD, and wiring harness.
Old Aug 31, 2004 | 01:24 AM
Kai's Avatar
Kai
Rotorphile.
92 (or 93) Integra GS-R water pump
92 (or 93) Integra GS-R timing belt
The throttle cable is easily availible used, no need to order that new.
That's all I can think of offhand that you'll need to order.
Old Aug 31, 2004 | 03:48 PM
ED9man's Avatar
ED9man
driver
The block is not taller?
Old Aug 31, 2004 | 03:51 PM
Kai's Avatar
Kai
Rotorphile.
The 92-93 GS-R makes use of a B17A1 engine... a stroked B16A. They share identical blocks with different crank/rod sets.
Old Aug 31, 2004 | 03:58 PM
ED9man's Avatar
ED9man
driver
cool, do you know of a resource that tells me all the USDM parts I have to mix and match for my JDM motor and tranny?
Also, totally unrelated, what does the charcoal canister do?
Old Aug 31, 2004 | 04:30 PM
ED9man's Avatar
ED9man
driver
please fast!
Old Aug 31, 2004 | 05:30 PM
Kai's Avatar
Kai
Rotorphile.
Uhh... here? Virtually every part is interchangable with the 92-93 GS-R, 93-97 del Sol VTEC, and 99-00 Civic Si engines, besides the distributor (no US counterpart) and injectors (most OBD-1 Hondas, let's say 90-91 Integra for a specific example)
The charcoal canister is an emissions part. Excess pressure from the gas tank is vented to it, and it is in turn vented into the intake manifold.
Old Aug 31, 2004 | 05:48 PM
ED9man's Avatar
ED9man
driver
What happens if it is removed and the lines capped?
thanks a lot
Old Aug 31, 2004 | 05:50 PM
Kai's Avatar
Kai
Rotorphile.
Well... I know in an RX-7 it doesn't hurt. I pulled mine a long time ago.
I don't think OBD-0 computers have an error code for that.
