Has anyone had this?
Old Mar 8, 2004 | 01:13 PM
L3V3L's Avatar
L3V3L
Default Has anyone had this?
Over the past few days (someone might have seen my problem on mikeygs post-but dont wanna steal his thread)...i have had a problem getting into 2nd and 4th gear, i really have to jam them in and it takes like 2-4 jams before i can get into gear and im usually left hangin in the previous gear for several seconds slowing me down...I have no idea why it is doing this It almost seems as if the gears are blocked or somthin...do i need a new tranny or clutch?...thanks...
btw im drivin a 91 DX, 5spd...
Old Mar 8, 2004 | 06:00 PM
A_PHOBIA's Avatar
A_PHOBIA
i got the same problem with my 88 hb,it most liklely your clutch cable.i have a shot clutch so i can have any play or i cant shit in to second or fourth either.when i messed with the clutch cable it whent in a lot smoother.
Old Mar 8, 2004 | 06:57 PM
L3V3L's Avatar
L3V3L
What did you find best for you? Adding more play or less? Because my buddy adjusted the cable today and now i have about an inch of play...
Old Mar 8, 2004 | 07:19 PM
low91crx's Avatar
low91crx
does it grind?........cause if so you your shifter forks might be broken.....you might wanna check that out, u dont want one to break when your out in the middle of nowhere......
Old Mar 8, 2004 | 07:33 PM
A_PHOBIA's Avatar
A_PHOBIA
less play,basically as soon as my foot slightly touches the clutch it is the begining of engagement. its's lows "really lowsy"but it needs to be done until i get my swap.
Old Mar 9, 2004 | 10:24 AM
L3V3L's Avatar
L3V3L
Alright thanks...i will check my shifter forks and im also gonna give myself less clutch play and we will see what happens after that
Old Mar 9, 2004 | 01:46 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Helms manual says .6-.8 inches of play before engagement
Old Mar 9, 2004 | 02:30 PM
cwood1388's Avatar
cwood1388
I had the same problem in my old del sol. I wouldn't doubt that the syncronizers have gone too.....does it jump out of gear? The way it's sounds like: you have to slam it into gear or it won't shift into gear propely.I always had to slam second gear to hell to get it to go in. I had those two problems before the tranny went.
