dead civic
Old Feb 29, 2004 | 04:32 PM
kd5dbl's Avatar
kd5dbl
Default dead civic
Well... my Civic died this afternoon. Driving down the road (in the rain), I guess a water line broke loose and sprayed water all over the engine bay. The trouble is now that the motor wont start. Could I have gotten water in to the distributer? If so, would a simple cap and rotor fix it?
Any help would be appreciated.
Old Mar 1, 2004 | 07:12 AM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
Are you sure you didn't do any damage to the engine? It didn't overheat and then seize up on you did it? If not, starting with the distributor is a good idea. You may be able to simply take it off, remove the cap and dry it out if thats the problem. Often letting the car sit over night will cure it if you've got water in the dizzy. Water in your spark plug wells could also cause soime troubles.
Old Mar 1, 2004 | 08:20 AM
kd5dbl's Avatar
kd5dbl
I really don't think it got all that hot... the temp guage was elevated, but not at the top of the scale. The starter is able to turn it over (without any horrible clunking noises). I'll pull the cap off tonight and see what's inside.
I'll also check the spark plugs wells... didn't think of that...
Thanks!
Old Mar 4, 2004 | 05:22 AM
kd5dbl's Avatar
kd5dbl
UPDATE:
Well, turns out that it was a simple matter... the heater hose right next to the distributer broke and ejected all of it's coolant right in to the the distributer. Let it dry out (and put a new cap and rotor on just in case) and all appears well at this point.
Thanks for everyones help...
egjoe
Nov 11, 2004 04:16 PM
Daniel
News & Rumors Archives
17
Sep 6, 2003 06:20 AM
jaje
19
Mar 26, 2003 03:58 PM
hyperlite
Engine Swaps, Tech & Tuning
7
Jan 29, 2003 08:19 PM
jaje
17
Jun 27, 2002 03:16 AM
