Engine shuts off while driving
Old Jan 14, 2004 | 04:19 PM
L3V3L's Avatar
L3V3L
Default Engine shuts off while driving
I am driving a 91 Civic HB DX (1.5 SOHC). My problem is that while driving my engine turns off. This happens randomly, could happen once a day sometimes once a week. It seems to happen after a hiccup or jerk in the engine. My Oil, Battery and Check Engine lights turn on as soon as the engine shuts off. I have had to deal with it for about the past 3 months - cold and warm whether, wet and dry and it always seems to happen. I have recently tried to solve the problem by putting in a new fuel filter, spark plugs and wires. If anyone knows why this is happening or how to fix it, all help is appreciated.
thanx
Old Jan 14, 2004 | 05:59 PM
WhiteRice's Avatar
WhiteRice
Does it happen during stops? Or just cruising down the highway at 55 and it dies?
Old Jan 14, 2004 | 06:03 PM
L3V3L's Avatar
L3V3L
It has happened cruising, accelerating, decelerating, and when at a complete stop.
Old Jan 14, 2004 | 07:21 PM
jaje's Avatar
jaje
HC Racer H5
do you get a code?...pull up the passenger side carpet and look at the metal box covering the ecu...you can see through a small window...count the codes...it will pause between codes if there is more than one
other than that sounds like the rotor in the distributor maybe going or a bad main relay (gets hot and will short)
does it start back up again?
Old Jan 15, 2004 | 06:13 AM
L3V3L's Avatar
L3V3L
alright thanx jaje...i will look into that...btw it does start up afterwards but you need wait about 2-5 minutes after it shuts off.
