RED SRS Light ON! 2000 TL
Old Jun 12, 2003 | 11:32 AM
Fugaezi's Avatar
Fugaezi
Default RED SRS Light ON! 2000 TL
Has anyone gotten an SRS light lit up on the dash? I had this happen to me a few thousand miles ago and I finally brought it into the dealer. They said it was simply a glitch in the system as a result of a changed battery. That light had been there since before I changed the battery. I had heard some horror stories about others having to swap out the brain for the SRS system. Does anyone have any more info on this?
Old Jun 12, 2003 | 02:47 PM
Pasha's Avatar
Pasha
Yeah. a few months back the SRS light popped up and i basically ignored it for the longest time. decided to bring it into the dealer and, well problem solved.
Old Jun 23, 2003 | 05:09 PM
HoustonCL's Avatar
HoustonCL
I've had a problem with that, too. I drive an 01 CL-S in which I've had the SRS brain (don't know the formal designation...) changed out twice. And both times were out of warranty, although (both times) the dealership extended what Acura calls a 'good will warranty'. Essentially, the problem is well known at Acura, and as long as you tell them you don't use you're passenger's side front seat as a storage shelf for anything but another passenger, they'll change it out sans charge. (At least, this is what happened in my case.) A good practice as I have been singing their praises ever since.
Old Jul 1, 2003 | 02:22 PM
romand's Avatar
romand
there is a bulletin out on this problem:
TSB Number: 02-015
Issue Date: Jul 02
TSB Title: Air Bag System - SRS Lamp ON/DTC's Set
have your dealership look it up and fix it.
Old Jul 13, 2003 | 12:16 PM
linkslinks's Avatar
linkslinks
Where can I find the case information you
are talking about? Is there a website?
