boost for first gen cl
Old Mar 31, 2003 | 07:46 PM
Singhg83's Avatar
Singhg83
BALLIN'
Default boost for first gen cl
as my subject states above, are there kits availible for boosting a first gen cl, turbo, supercharger?? just curious
Old Apr 1, 2003 | 09:55 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Only custom made ones.
Old Apr 5, 2003 | 10:37 AM
KC CL 1785's Avatar
KC CL 1785
Incorrect, there is a turbo kit, but it is for the accord, I believe you need some modification. Over on the www.acl board, njnejdb or something like that has done the fitting. His first gen puts down 250 something in torque and hp to the wheels.
Old Apr 5, 2003 | 09:26 PM
AcuraTL's Avatar
AcuraTL
If you have to modify it, than basically you have to do some custom work to it to make it fit. So what's so incorrect about my statement?
Old Apr 7, 2003 | 06:45 AM
Singhg83's Avatar
Singhg83
BALLIN'
well, not tring to be rude, but, what was the series name for the 2.2 cl motor? just curious
Old Apr 8, 2003 | 02:22 PM
d98clturbo's Avatar
d98clturbo
i'm high...on boost!!
i also have turboed my cl (twice...1st with the stock motor and 2nd with the h22)
the accord kit bolts right up to the cl no need to modify anything..the accord and cl have the same front end..you can get a kit from F-max or Drag...just order it for a 94-97 accord
the kit i had on the stock motor was a Drag gen II kit (piece of ish in my opinion) niedejb from acl.com has the F-max and from what he says its alot better and you get alot more with the kit too
the engine codes are f22b1 & f23a1
Old Apr 9, 2003 | 06:27 AM
Singhg83's Avatar
Singhg83
BALLIN'
thanks alot d98, i just wanted to know cause i was just courious if an h22 could fit into the 2.2cl.
