1999 acura 3.2
Hi, The heater on my acura only blows cold air, i'm pretty sure I have to replace motor for the heater box, but need some help, step by step kind.thanks... ca
I haven't done that yet. You go first! :eek:
I have found that turning the temp control all the way up (90 degrees F) for a minute will move the door and the heat will return. |
I've had to do that same thing with my heat since day one (Jan. 00) with my 00 TL3.2.
Be nice if someone would post a real fix for this (other than turning the temp all the way up). |
The problem is with the hot air mixture control motor under the dash. They are expensive. :(
You replace yours first, tell us how much it costs for the repair. ;) |
