1994 acura vigor factory car alarm
Old 02-24-2009, 10:46 AM
jackmain
jackmain's Avatar
Default 1994 acura vigor factory car alarm
my 94 acura vigor factory car alarm wont shut off and i cant start up car is there anyway that i can disarm alarm
Old 03-19-2009, 08:20 AM
nickw84
nickw84's Avatar
Default Alarm Disarm
Is there a fuse for it? Do you have the manual for the vehicle? If you disconnect the negative (black) battery cable for 20 minutes that should clear out the car's computer (make sure you have the radio code handy for restart if it's the factory radio)...just a few thoughts
Old 04-15-2009, 12:27 PM
TranceVig
TranceVig's Avatar
I just put the key back in. hmmm, doesn't happen to me unless, i went in from the other than driver side.. I'm getting a whole new upgraded alarm, so I'm not trippin on that.
Old 04-28-2009, 09:18 AM
meazz1
meazz1's Avatar
alarm should turn off if you put the key in the driver side door and turn.
Old 08-05-2009, 08:50 PM
shawnhu
shawnhu's Avatar
Problem with the Vigor's factory alarm is that the electronic door lock actuator loses contact with the switch over time due to corrosion and will not send the signal to the alarm unit. The car will think that the door was not unlocked with the key, and will trigger the alarm to go off.
To remedy this, you can open the door from the passenger side like someone already mentioned, or fix the lock actuator. There's some great write-ups for this problem over at the Yahoo Groups site. You can find them over at acuravigorclub.com and read through some of the Timely Topics Articles, written by members of the Yahoo Group.
Hope that helps.
Shawn
Old 08-09-2009, 02:33 PM
luckyv
luckyv's Avatar
Default wrong place
I just bought a 96 A when i push the alarm key it keeps unlocking and it will do that for a few sec does any1 know wat is wrong with it its the factory alarm
