2003 TL won't start
Old Jul 30, 2007 | 03:57 PM
etspam's Avatar
etspam
Default 2003 TL won't start
I have a 2003 Acura TL from my sister, and the car won't start. When I try, either the engine attempts to turn over a couple times (slowing down), then the starter starts to click continuously, or the starter clicks continuously from the get-go. If I jump it, it will start and run fine. I'm thinking this is a battery issue (the light seems dim or out on it), but driving it around for half an hour to an hour doesn't seem to charge it significantly, and if I leave it overnight, the same thing happens in the morning. It's only been 4 years for the battery, and I think that's kind of low in terms of battery life, and I've read some forums where it says it might be the starter or the solenoid in it, so am not sure, short of taking it in. Will try to borrow a charger for the battery and see if that makes a difference. One thing I did note, that if I turn on the lights, then try to start it, the lights immediately cut out instead of dimming.
Old Jul 31, 2007 | 11:37 AM
bob01721's Avatar
bob01721
Sounds like your battery won't take -- or hold -- a charge. Any place that sells batteries should be able to test it for "no charge."
Old Jul 31, 2007 | 01:06 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Battery problem.
Old Jul 31, 2007 | 01:08 PM
94civicEX's Avatar
94civicEX
I got worms.
You need a new battery, batteries that old have a hard time holding a charge.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jul 31, 2007 | 09:21 PM
coctail's Avatar
coctail
could it be the alternator going out? Not recharging the battery?
Old Jul 31, 2007 | 09:39 PM
AcuraTL's Avatar
AcuraTL
Highly unlikely. If your alternator was bad, your car won't be running after a jump start because a dead battery with bad alternator = dead car.
Old Aug 1, 2007 | 11:58 AM
etspam's Avatar
etspam
Thanks for the tips. I tested the voltage of the battery, and it's in the 10-11V range at this point. Will try charging with a borrowed charger, but don't give it much hope. Does anyone know Costco sells the correct size battery for replacement? I think the size is BCI 24.
Old Aug 1, 2007 | 02:21 PM
AcuraTL's Avatar
AcuraTL
Each Costco carries different sizes but that is pretty standard so they should have it. Forget about charging it, just go get a new battery and swap it. Your battery can read 14 v and still it can be dead. Amperage is where the power is.
Old Aug 3, 2007 | 02:55 PM
coctail's Avatar
coctail
I would still test the alternator!!!
Old Aug 3, 2007 | 02:57 PM
coctail's Avatar
coctail
if the battery has enough juice it will start the car and run until it runs out of juice.
