Acura TL VCA, ABS, VCA indicator lights on
Old Feb 11, 2007 | 03:51 PM
Jim Raffetto's Avatar
Jim Raffetto
Default Acura TL VCA, ABS, VCA indicator lights on
I have a 2002 Acura TLS. Recently the VSA, ABS and warning triangle lights have come on. They are coming on and off randomley with no pattern. The car drives normal. I took it to an Acura dealer and they spent 4 hours troubleshooting the problem. They found a suspect loose ground wire. This cleared the problem for four days but the lights started coming on ... or off again. The error codes are 53-1/16-1/51-1, Abs pump relay short, wheel sensor failure and pump failure. I took the car back and they said it needed a new motorpump at $2,000. Help!! is there something I can do? I don't trust the dealer for reasons I won't go into. I also then took the car to a independent Honda repair shop. They said the sensors were in spec and it was unlikely the pump was bad, in fact they said it was working. Probably an electrical problem. I don't want to dump endless money into this. Does anyone have any suggestions. The light have been on for four days now.
This is my first post. Jim
Old Feb 24, 2007 | 05:21 AM
sheekdude's Avatar
sheekdude
I had the same problem with my 99 tl. Turned out to be one of the abs wheel sensors. If you have a multimeter, check the output voltage.
The one that gives you the lowest reading may be faulty or has a short/continuity issues.
Old Mar 1, 2007 | 02:23 PM
Jim Raffetto
Default Problem solved
Thanks for the reply.
I solved the problem the easy way, I got rid of the damn car.
