Anyone use the Fumoto valve?
Old Mar 1, 2006 | 09:57 PM
johnnyreb's Avatar
johnnyreb
Default Anyone use the Fumoto valve?
http://www.fumotovalve.com/
Do I need the adapter for a 2004 TL?
Old Mar 2, 2006 | 11:59 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
I can't comment on it because I have never used one before. But it only takes me less than a minute to take the drain bolt out, not that hard.
Old Mar 2, 2006 | 02:43 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
x2
Old Mar 3, 2006 | 07:21 AM
Lawrence Coppar's Avatar
Lawrence Coppar
I installed one many, many years ago on my old Mercedes (owned car for 26 years). The reason I did it was because the drain plug on the 450 engine is 24 mm (huge). When you removed it, the oil came out so fast that it would overflow the concave portion of my drain container because the oil would flow out of engine much faster than it would enter container. The 450 engine holds about 10 quarts of oil.
The valve works well. Never had a problem with it. It never accidentally opened and does not leak. Now I have a lift and a reservoir with one of the extendable funnel things on it so the size of the drain hole is moot. But I keep the valve in that engine so I don't have to anneal the copper sealing gasket.
