Almost done installing my new Pioneer Sub!!
Old Aug 24, 2002 | 06:22 AM
rmarin2's Avatar
rmarin2
Default Almost done installing my new Pioneer Sub!!
It wasn't a very difficult task, just very time consuming! I have to say that the Pioneer sub is a definite improvement over the stock sub! It doesn't give the same sound as a ported sub, but its very close to it!
I was able to fit the sub in the stock location by removing a metal bar that runs just underneath it. It was spot welded in 4 spots, so I simply drilled them out without any problems. I then had to enlarge stock hole so that I could fit the new 10" sub. I used a dremel with a metal bit. That took the most time because I wanted to be careful and neat with it! I made a new 9" diameter hole and fit the 10" perfectly. I used some 1/2" foam insulation between the sub and dash to help with vibrations. I used 14"x2" hex self tapping screws to bolt the sub down.
In order to the stock cover back on, I had to cut some of the interior plastic as well as remove the red lens for the stop light. Since I have a spoiler with the LED it didn't matter. You also can't tell that the red lens is missing because of my tint! So I was lucky with that!
All I really have left to do it just secure the sub a little bit more! Other than that it's done! I am happy with the new results!!
Pics will be posted shortly!
Thanks to all those that helped with all my technical questions!!
-Rich
Old Aug 24, 2002 | 08:03 AM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Hope you don't run into vibration problems on the rear deck. You might want to reinforce with a 1/2" MDF. Hope it works out though.
Old Aug 24, 2002 | 01:24 PM
rmarin2's Avatar
rmarin2
Well so far so good. I set the volume all the way up and played some heavy bass music, reggae that is, and so far so good!!
Old Aug 24, 2002 | 07:03 PM
AcuraTL's Avatar
AcuraTL
Are you using the stock amplifier?
Old Aug 25, 2002 | 06:37 AM
rmarin2's Avatar
rmarin2
No using an old phoenix gold amp. I'm running the signals into a crossover before it hits the amp. I have the low pass filter on the crossover set to 120Hz. If I set it lower it sounded like the sub was cutting off. I'm getting pretty good sound. If I was to get a better amp I'm sure it would push a little bit cleaner!
Old Aug 25, 2002 | 08:20 AM
AcuraTL's Avatar
AcuraTL
If you are using the stock wiring harness, then you don't need an extra low-pass filter since it is already been crossed over.
Old Aug 25, 2002 | 10:45 AM
BonzoAPD's Avatar
BonzoAPD
sounds like a good mod. Good luck with it. Hope to see some pics soon.
scubadorg
Sep 20, 2004 10:55 AM
