Tire size question
Old Nov 28, 2004 | 02:16 PM
Vigorous1's Avatar
Vigorous1
Default Tire size question
I have 17x7 inch rims with a 215 45 tire size. How do I go about switching to a 40 series(i prefer a lower profile tire), or can I without going 18s? Can i go 215 40? Or if I go 205 40 what differences would it make in driving performance if any.
Old Nov 28, 2004 | 07:32 PM
AcuraTL's Avatar
AcuraTL
Lord Vader Moderator
Just remember, you have to keep the overall diameter of the wheel as close to stock as possible. While you can go to a lower profile tire, you will have to compensate it and get wider tires so the overall size is the same. If you don't, your speedometer will be off. Go to www.tirerack.com and read up on tire size difference.
Old Nov 28, 2004 | 08:12 PM
Vigorous1's Avatar
Vigorous1
Ouch! According to the graph the closest possible combination to stock is 245/40-17...Is that possible for the vigor to go that wide? Would that look ridiculous?
Old Nov 29, 2004 | 11:11 AM
AcuraTL's Avatar
AcuraTL
I think you will need to get 18s if you want 40 serie tires.
Old Nov 29, 2004 | 12:25 PM
Vigorous1's Avatar
Vigorous1
Old Nov 29, 2004 | 01:53 PM
luky1380's Avatar
luky1380
no need 18s just go with 40 u not gona have any problems
or just go to
www.whalentire.com
they will gave you al possible sizes for your car
Old Nov 29, 2004 | 06:46 PM
AcuraFanatic's Avatar
AcuraFanatic
It throws your speedometer off a tad but not much. 245's are likely to be too wide...I'm at 215 and at a 2.3" drop I barely clear when turning.
Old Nov 30, 2004 | 02:12 PM
Vigorous1's Avatar
Vigorous1
So are you at 215-40-17? What about safety wise is it dangerous? I asked the guy at tirerack and he said being that the car is apretty decnt size it might not carry the load well enough....
