which alpine type r's?
hey guys,
I'm getting a usx600f amp, which has 2 ohms per channel, to power 2 10" type r's. I just wanted to make sure that i need to get the 2+2 ohm subs for this amp, and not the 4+4 ohm ones. Am i right? thanks |
Depends on if youre running it bridged to mono or not.
If you're running your sub amp bridged to mono, get 2+2 ohm dual coil subs and wire the coils in series with each other on each sub, then wire the two subs together in parallel and you'll come out at 2 ohms total. If youre running two channels unbridged to the box (one sub per channel), get 4+4 ohm dual coil subs and wire the coils in parallel on each sub. This will put each sub at 2ohms. This is the ohm ratings you can get from a single sub of either type: 2+2 dual coil: 4 ohms with the coils in series, 1 ohm with the coils in parallel (don't try 1ohm unless your amp is hella beefy). 4+4 dual coil: 8 ohms with the coils in series (waste of amplifier power), 2 ohms with the coils in parallel. Hope that helps. |
| All times are GMT -8. The time now is 10:49 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
