clifford matrix RS3 questions, help plz!!
Car: RSX Type S
I have the clifford matrix rs3. (2 way pager) I have some specific questions.
I have bought additional piezo sirens i want to hook up with the main alarm.
1. If I hook up 3 of these additional sirens, is it true the volume of all the sirens go down since it's drawing from the same source of power?
2. I also have the self powered backup siren (works off key). Does this go off at the same time the main siren goes off (when alarm is triggered) so in essence I hear 2 alarms? Then when I de-activate the alarm, both turn off? Or does the backup only go off if the main alarm is cut? I noticed on the back up siren, there are 4 wires (power/ground/activate wire/deactivate wire)
3. I have the DEI 530T window module. Can one touch ONLY work from the driver's side or can I make it so it works for both the driver and passenger side?
4. Do I need to use harness 2? I heard that I would still need to wire the power and have the harness plugged in, but just cut all the other wires.. is this true?
Thanks in advance for any help!!
