Need Help, cant find correct wire
Old May 25, 2003 | 10:36 AM
xenocron's Avatar
xenocron
Default Need Help, cant find correct wire
Looking for the Factory Alarm Disarm No Unlock wire in a '99 Accord EX
Anyone give me any help here...i know its a blue wire, i just dont know where to look
thx
Old May 25, 2003 | 11:05 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
you're gonna have to go to the drivers door key cylinder... its a green & red wire there... needs a negative trigger...
or it can be found at the drivers multiplex unit, as a blue wire like you said... also needs a negative trigger.
Both of which are inside the door.
Old May 26, 2003 | 07:54 AM
xenocron's Avatar
xenocron
dont either of those wires run into the car?
im afraid it will be rediculously hard to run a wire from the car into the door
thanks
Old May 26, 2003 | 08:44 PM
SumAccordGuy94
Older Honda Fanatic
from the sounds of it, your car uses a multiplexed system... meaning one wire can do 5 different things... so i'm sure it goes into the car somewhere, but its gonna have other jobs and probably screw things up for your alarm.
IT is a pain to get wires into the door... but it seems in your case, it'll have to be done.
Old May 27, 2003 | 04:05 AM
xenocron's Avatar
xenocron
k, thanks for your help
