sony xplod drawing too much
It's my first day.
it's blowing the onboard 30 amp fuse. Tried to hard wire it and of course the wire got very hot. Seems like it happens after the amp finishes its self-diagnostic.
I had it all apart and looked it over for bad grounds and broken solder joints. Any other suggestions? Think i can get sony to warrantee it?
Ever wonder why they never really named it Sony EXPLODE???
Does the amp go into protection after it does diagnostics? What exactly did you try to hardwire? The fuse?
Take it to a Sony Service Center, if you have proof of purchase with a date within the warranty time frame they should cover it, if not they charge a standard flat rate for repair.
It's my first day.
it was a freeby cuz the guy ****ed it up, i would never ever use sony. apparently he was hitting too hard and it stopped working. maybe ill do one of those buy a new one, take it back swaps
let best buy deal with it.
It's my first day.
Originally posted by arch iceman
Make sure the serial number isnt printed anywhere on the box like on that white sticker. That way when you take it back and the serial numbers dont match.....
im sure its on there somewhere, they never check.
