Wiring Guru's HELP!
Banned
Wiring Guru's HELP!
Some of you may think im gay or some ****, but i don't care...
i was wondering on how to install interior neons, and a led light in my crx...thanks
Tastes like DonkeyBalls
pretty simple.. 2 wires... one ground and the other to a 12 volt ignition wire. I'd also hookup an inline 10 amp fuse as well to the positive wire.
I just patched into my cig. lighter positive wire and grounded the black wire to a solid metal part on my car.
hope that helps.
hope that helps.
wire 1 (red)
(12V power)<------------------>(fuse)<------------------>(neon bar)
wire 2 (black)
(bare metal surface)<------------------>(neon bar)
wire 2 (black)
Originally posted by Eklypse39
wire 1 (red)
wire 2 (black)
wire 1 (red)
wire 2 (black)
Some cheap pepboys neons dont come with red/black coloring..
I have seen clear/clear &white stripe wires attached to a cig lighter adapter.
Cut off the adapter... and wire as normal:
clear is for ground
clear & white stripe is for 12 volt ignition
