Need ideas.....
Old Dec 9, 2002 | 03:22 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default Need ideas.....
i need ideas on how i can hold my one 15's box down to keep it from rolling around in my trunk.... No matter what i can't drill holes in the false floor... so no bolting it down unless i buy a sheet of plywood or something
Old Dec 9, 2002 | 03:34 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
Old Dec 9, 2002 | 04:12 PM
yeh.. buy a sheet of plywood and make the base realy wide, so it wont tip over or anything
Old Dec 9, 2002 | 05:43 PM
Toxis's Avatar
Toxis
Car Audio Manb*tch
I would have to say.......................
plywood ownerages. Or you could get something along the line of an L-bracket...but other than that, plywood!
Old Dec 9, 2002 | 09:36 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
that's what I did in my Civic, need to do it in my Accord, damn velcro isn't working:madfawk:
Old Dec 10, 2002 | 10:10 AM
Matt86's Avatar
Matt86
vtec ownz j00
wouldn't an l bracket require drilling into the false floor?
Old Dec 10, 2002 | 12:34 PM
illusion's Avatar
illusion
here I made a little picture for you
grey is "your trunk"
red is "your box"
blue are proposed braces
green are optional placement, but you'd need to get tricky to mount on the edges of the box.
Personally I'd make the arm of the braces out of 2x2 firring strips(2" by 2" wood) and make the end pieces out of 1/2" ply, carpet them, and make it so they are just long enough to fit, but you have to nudge them in , also you could screw them into the box if you don't plan on taking them in and out, that way your box won't slide all over the place. If I have time I'll try and find the brace I used to have to keep my amp rack from sliding backwards ever time I hit the gas, and I also had my rally braces for my subs to keep them from tipping in when I was playing rally driver lol. The box I have in now is so freaking huge, I just put a carpeted chunk of 2 x 4 and push the box forward, and put it in. No sliding
Alternatively you could put two braces in the front instad on one, to clear the sub.
Old Dec 10, 2002 | 12:46 PM
Matt86's Avatar
Matt86
vtec ownz j00
thanks man.. i understand now :thumbup: :thumbup: :thumbup:
