speakers not working in 94EX. HELP!!
I just had a new pioneer deck installed the other day. I just replaced the drivers side front door speaker today (which took half the morning to get the door panel off). I had to take off the mount that the stock speaker sat in because if I didnt the speaker wouldnt fit. I had just got done hooking it up and mounting it and everything was fine until I closed my door. Poof! No sound from all the speakers. I checked to see if there where any fuses blown but didnt find any. Can anybody help me?! This is really frustrating.
when you closed the door, the speaker contacts could have shorted with the door. This would have burned out your units mosfet amp.
Remove the door panel and check the wiring. If a wire came loose and is hitting metal or the other lead, it would cause the amp in the deck to turn off. It should work after you fix the wiring if this is the case.
were there any screws holding the speaker cover on the front door or are they just clips,
if there are how did you remove them |
