97 accord amp wiring issue
Old 04-23-2008, 04:15 PM
MrWiggles
Default 97 accord amp wiring issue
Wondering if you guys would know.
I got an amp hooked up in my trunk I have it grounded on the back-bottom of my back seat BUT the amp will only cut in and out if you put pressure or wiggle the ground wire, the wires are all crimped perfectly and connected correctly but it will only play if the seat is folded down and you mess with the wire? I have had this problem before though on a 91 accord and I moved the ground wire from the backseat to the side of the car but on the 97 there's no place on the side i can reach without causing destruction, any ideas?
MrWiggles is offline
Old 04-23-2008, 05:27 PM
mr22na
Miss It.
mr22na's Avatar
just a bad ground...
try finding a pre existing bolt you can ground it to.
mr22na is offline
Old 04-24-2008, 11:21 AM
Tedmond
never use a seat and groundin it there. Use the chassis. There will be enough if not plenty of areas for you to drill for a ground.
Tedmond is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
