05 Accord Amp Mounting Locations
Hi,
Looking for suggestions for some good locations to mount an Alpine Amp and Kenwood powered sub in a 2005 Accord Sedan. I like the stuff to be low-key, out of the way as much as possible and still allow use of fold down seat etc. The truck cover over the spare is huge and takes alot of otherwise usable space. don't want to re-invent the wheel. Thanks!!
Thanks totalimmortal
It's been a bit cold here since I got the car so I haven't got a chance to look under the seats for space. That would be my first choice for the amp. Thanks!
just a note, when u remove ur seat, if u see any wires that come out of it, make sure u remove your negative battery terminal, remove what u need to do, reconnect wiring underseat if there is any (airbag pressure sensor, seatbelt) then reconnect battery.
