2007 accord
I have 2 questions, im pretty good at wiring , but with this new 2007 accord, i cannot find a place to put the amp wire thru the firewall, does anyone know a good place to run that wire, and also where is the best place to ground the ground wire in the trunk since they come with the plastic flooring in the accord.
well grounding in any car usually requires any solid metal point w/at least paint as possible
hope you can find one and if you do, share :) |
