new setup has problems...
Old Jun 11, 2007 | 04:33 PM
88'CRX's Avatar
88'CRX
Default new setup has problems...
okay i have a kenwood mp5032 head unit and it stopped playin cds so i got a kenwood kd301 external cd player hooked up and it worked fine.. this mornin i hooked up two amps to run subs and 6x9s.. after i wired all the amps i turned on my car to see if the amps would turn on.. and when i did my head unit or cd player would not even turn on.. i checked the fuse and its fine and i disconected everythin and put it back on and stil the same... the head unit is stil gettin power cuz a red light stil flashes when the face is off and for some reason i could eject a cd after i unhooked and hooked everythin back up... does anyone know what my problem is and how i can fix it?...
Old Jun 11, 2007 | 08:08 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
How many fuses did you check?
Old Jun 12, 2007 | 08:16 AM
88'CRX's Avatar
88'CRX
just the one on the head unit... what other ones should i check??
Old Jun 13, 2007 | 07:01 AM
totalimmortal
MalleusMaleficarum
Check every fuse in the car, you'd be surprised what fuses can blow when working on stereo components.
Old Jun 13, 2007 | 09:59 AM
88'CRX's Avatar
88'CRX
yep checked the one under dash and it was blown...thanks for the help
