del sol speaker size?
What size speakers are in 1995 del sol SI?
61/2 or 5 1/4 all the way around I do believe. Be carfull with the depth. You may have to cut the stock speaker bracket. I personally took mine out and made my own speaker mount using the stock as a template from plywood and mounted it in its spot then mounted the speaker to that.
Good luck |
