Amp goes into protect mode, please help
Old Jul 25, 2006 | 03:39 PM
burnrubber's Avatar
burnrubber
Nucking Futs
Default Amp goes into protect mode, please help
my amp was used for a sub, then i ran two 6x9 and then just unhooked the speakers. so it was getting power, just wasn't being used. today i go to hook it up to a sub and once i plug the rca cables in it goes into protect mode. If I unplug them it shuts off. what;s the problem, it was working just 2 days ago?
Old Jul 26, 2006 | 06:55 AM
HONDA_driven's Avatar
HONDA_driven
got vtec?
go to radio shack or wal-mart and get some $4 rca's. pull out your head unit and plug 'em into the radio and amp. this will tell you if your other RCA's are damaged.
Old Jul 26, 2006 | 07:18 AM
flyromeo3's Avatar
flyromeo3
Did you connect the positive and negative lines backward?
Old Jul 26, 2006 | 04:41 PM
HONDA_driven
got vtec?
The amp would instantly blow the Fuse. Then do nothing ( had he done that)
Old Jul 27, 2006 | 07:58 AM
burnrubber's Avatar
burnrubber
Nucking Futs
i have two amps and this one has rca's running from the other. the power and ground cables are hooked up the same way they were when it was working. i also had bought some new rca's and same problem.
