Fiberglass Subwoofer Boxes
Originally Posted by I_S_R
Has Anyone Ever Converted Their Subwoofer Box To Fiberglass????? If So Dont You Have To Buy Some Sort Of Fiber Cloth???where Can I Get These??????
You can build a sub box without using mat it just wont be as durable. A buddy of mine use's felt in his applications, That combined with silca powder should give it enough integrity to withstand the presure from the sub. Peronelly I use the mat cause it bonds way better with the fiberglass.
under no circumstances should you use just felt, fleece, tshirts, etc for any piece that requires strength - you are just going to be building a heavy, expensive and weak piece...
resined fabrics (non fiberglass) may be hard, but it's very very brittle
Originally Posted by 97teg
You said "just" so im guessing if you put a bunch of fiberglass mat over the resined fabrics it will be ok?
Assume that the original "stretch" of every-day fabric adds no strength to your part....
