Deck NOT WORKING.....
Old Jun 6, 2006 | 03:05 PM
kg_96accordLX's Avatar
kg_96accordLX
Default Deck NOT WORKING.....
i just bought a used deck at a pawn shop....the brand-Autobahn...something like that....but yea...i wired everything together then connected the hareness....then played it with a cd it was working all fine untill i was putting it where the stock one was it just died out....and then i checked all the wires and everything else again....but still not working...i looked at the fuses..and two of them blew out so i switched them out and put new ones...and it still didnt work....and also something's wrong with the time...usually when i start the car the time will show but now when i turn it on it doesnt.....plus my signal's doesnt work....ANYONE COULD KNOW WHATS WRONG???.......
Old Jun 6, 2006 | 03:23 PM
mishqua's Avatar
mishqua
Did you cut into the factory wireing harness (for the radio) of the car? There shoudn't be any reason your signals don't work unless u cut the factory harness. You could look at the main power distribution and see if ya blew a fuse there.
Old Jun 6, 2006 | 05:37 PM
ewood87's Avatar
ewood87
Eric Wood
sounds like you shorted something / blew a fuse.
Old Jun 6, 2006 | 08:17 PM
b00gers's Avatar
b00gers
You blew a fuse. Check the fuses that are under the hood and under the dash.
Old Jun 6, 2006 | 08:24 PM
Shallow_Bay's Avatar
Shallow_Bay
teh accord guy
i know whats wrong. buying it from a pawn shop. which means that theres a 95 percent chance it was stolen from someone elses car. which means that theres no telling what the hell could be wrong with it. just my 2 cents, but thats from a guy who got 2 head units stolen now...
Old Jun 6, 2006 | 08:49 PM
b00gers's Avatar
b00gers
I dont think something is wrong with the unit. It worked fine until he moved it. When you move it into the dash the wires will move...a bad connecting job can short it out and blow some fuses. Having the signal and clock stop working is a real sign of a blown fuse since in some cars, they use the same fuse (clock and radio).
Old Jun 7, 2006 | 07:16 AM
rcurley55's Avatar
rcurley55
it's an Autobahn that you purchased from a pawn shop - that's probably what's wrong with it.
Gotta make sure all the fuses are good (not just look good, but are good) and make sure it's grounded properly. On top of that, ensure that the constant 12V and switched 12V lines are hooked up correctly.
Past that, if it's still not working, it's probably a dead unit.
Old Jun 7, 2006 | 10:11 AM
kg_96accordLX
thanks yo...preciate it..
Old Jun 7, 2006 | 03:20 PM
mishqua's Avatar
mishqua
lol is there a fuse in the back of your head unit?
