Scratching noise coming from 6x9's
Old Mar 20, 2006 | 08:34 AM
travis3838's Avatar
travis3838
Default Scratching noise coming from 6x9's
I have an '01 accord coupe with tweeters in the front, 6.5's in the doors, 6x9's in the rear and 2 12's in the trunk. I replaced the OEM radio with my kenwood head unit and ever since there has been a scratching noise coming from the speakers. At first I thought the tweeters were blown so I took those out but now it is coming from the rear speakers. Bad wiring? Tweeters blown on the 6x9? Any help is appreciated thank you
Old Mar 20, 2006 | 10:42 PM
b00gers's Avatar
b00gers
When do you hear the scratching noise? Loud volumes? Low volumes?
So you saying it started in the front, then moved to the back?
Old Mar 21, 2006 | 04:32 AM
travis3838's Avatar
travis3838
Yeah at first I only heard it coming from the tweeters, but it may have been coming from the back as well at the same time. Also when I accelerate, as my engine goes to higher RPMs, the noise gets louder as well. I can hear the scratching only at low volumes because the sound of the music covers it up at higher levels.
Old Mar 21, 2006 | 06:32 AM
b00gers's Avatar
b00gers
Do you have an amp? So far it sounds like a grounding problem. Check the ground connections on your deck, and also if you have an amp.
Old Mar 21, 2006 | 06:58 AM
orbit77's Avatar
orbit77
i second the idea of having a bad ground
Old Mar 21, 2006 | 07:59 AM
ariza034's Avatar
ariza034
SuMaDiNaC
yah im guessing bad ground ...try re grounding it sand the paint of the point where your trying to ground it
Old Mar 21, 2006 | 08:04 AM
travis3838's Avatar
travis3838
Yeah I have a 4 channel MTX underneath the passenger seat, I'll check the ground, thanks for the help, hopefully it will remedy the problem
Old Mar 21, 2006 | 07:10 PM
orbit77's Avatar
orbit77
also since you have a 4ch, it could be your rca's. what kind are you using and how are they ran and also how is the power ran too.
