no sound coming from amp
i have a pretty old soundstream 2 channel amp that i bridged to power my sub. it stopped working, so i tried hooking it up to the left output and the right output, neither worked. i checked the fuses and of course they were blown, so im like.. nice, thats the problem. i change the fuses, still nothing.
any ideas? any thing else i can do to test it, or is it time for a new amp?
Older Honda Fanatic
did the fuses blow again when u put new ones in? These are the fuses on the amp, correct? If they're blowing then there is an internal problem, amp is probably screwed.
i havent checked the fuses again, but the light on the amp still lights up, so i am assuming that they didnt blow.
edit: yes they are the fuses in the amp, not off the battery.
im gonna ahve to check them later this week, since im at school and my car is a good 15 minute walk away h:
Older Honda Fanatic
if the fuses in the amp blew, chances are that somehow there was a short in the speaker wires... im not too familiar with soundstream amps, but anything is possible.
Check all your speaker connections... inside and outside the box... if you were playing it loud when it quit, it is very possible that a short in the speaker wires would blow the fuses. Now if there is still a short, the amp is probably in a protect mode...
im actually trying to play music through my 12" highs that i have in my backseat, so i know its not a connection to the sub or anyhting. when you say a short in the speaker wires.. does that mean i should try new wire? h:
