thumping noise
Old Jan 19, 2006 | 05:58 AM
flyromeo3's Avatar
flyromeo3
Default thumping noise
Theres this strange thumping noise that comes up when im in my car.
At times the music could be playing at a moderate level and all of a sudden the bass starts to thump extensively loud. I could lower the volume all the way down and the thumping is still there.
I typically turn the radio off/ on and it goes away. Im certain its my amp causing this problem.
Im using an audiobahn A8000T amp to a 12' L7. Just to be certain im going to replace the amp with another of the same.
Has anyone else encountered this problem?
Old Jan 19, 2006 | 07:07 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
I remember having that exact problem. I switched out the RCA's hoping it would fix it and it actually did.
Old Jan 19, 2006 | 09:41 AM
flyromeo3's Avatar
flyromeo3
I was thinking that also but even when I have the radio volume lowered sometimes the bass still makes that nasty thumping noise.
I think Ill replace the AMP and see.
I want to remove my XM tuner also.
Old Jan 19, 2006 | 10:49 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
How long is your ground wire? Many problems can be traced back to a bad ground. Are the subs moving a lot when this is happening? A friend of mine had the same problem, even with the radio turned all the way down. Turned out he had a terrible ground. Wish I had taken pictures of that mess.
Old Jan 19, 2006 | 02:02 PM
flyromeo3's Avatar
flyromeo3
I may have to tighten down the amp though. I believe it does move a tad.
Old Jan 19, 2006 | 08:19 PM
b00gers's Avatar
b00gers
Make sure all your connections are tight. Loose RCAs might do that, samd with a bad ground location.
Old Jan 19, 2006 | 09:49 PM
orbit77's Avatar
orbit77
my roommate's amp did the same in his mr2, i got sick of it and beat the crap of it and it stopped for a bit but i ended up putting my spare amp in there. the amp was actually just too old and was abused so it was gone anyways.
Old Jan 20, 2006 | 05:00 AM
flyromeo3's Avatar
flyromeo3
thats the same exact thing i've been doing.
Once it thumps I pound on the amp with a closed fist. Then it goes away.
Old Jan 20, 2006 | 09:05 AM
b00gers's Avatar
b00gers
Instead of pounding on it. Try and wiggle some of the wires on the amp. Maybe you hvae something loose and pounding it puts it back in place.
Old Jan 21, 2006 | 08:24 PM
Bmpn's Avatar
Bmpn
Audiophile
sounds like an rca is coming loose, or maybe internally the rca connection/wiring is fawked. a ground would cause it but not as frequently as an rca... make sure the radio is off when playing with rca's unplugging them and all. good luck.
