wierd noises....
Old Jan 11, 2006 | 10:29 AM
b00gers's Avatar
b00gers
Itll be easier to tell if you can find out the model number. But put the biggest that will fit on there h:
Old Jan 11, 2006 | 11:46 AM
mr.crx's Avatar
mr.crx
well thats the thing it didnt really fit so i kinda kust pushed it in there could that be th problem?
Old Jan 11, 2006 | 04:55 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Use spade terminals. A 1600 watt amp should be able to accomodate them. You can never over-do the guage wire you use. If you use 4 gauge ground, then use 4 guage power.
Old Jan 12, 2006 | 05:25 AM
mr.crx's Avatar
mr.crx
the power wire i got was a lot bigger then the ground is that not ok?
Old Jan 12, 2006 | 07:54 AM
b00gers's Avatar
b00gers
They should be the same size.
Old Jan 12, 2006 | 08:42 AM
mr.crx's Avatar
mr.crx
ok guys thanks when i get off of work i will try my best to fix...if i dont succeed throw it in the garbage
