trunk rattels
Old Nov 13, 2005 | 02:35 PM
sina518's Avatar
sina518
2draccord
Default trunk rattels
my trunk rattles a lot anyone with the same problem if so whats the best way to fix it. maybe dynamat?
Old Nov 13, 2005 | 03:38 PM
b00gers's Avatar
b00gers
You have to spend the time to isolate the rattle. It can be cause by thin sheetmetal (common in Hondas) or things hitting against each other.
If it is thin sheetmetal, putting a sound deadener like Dynamat will help. Although you have to know where to put it. And there are also tons of alternatives out there that can be cheaper. To isolate the rattle, I find that using a test tone CD helps. That way the subwoofer will be playing a constant tone that will cause the rattle, and the freqs from the tweets and mids wont distract you from finding the rattle. You can DL these test tones online.
If you have two things hitting against each other, put something between them.
Old Nov 13, 2005 | 05:49 PM
sina518's Avatar
sina518
2draccord
thanks im gonna look into it.
