92 civic amp wiring?
Old Jul 26, 2005 | 03:41 PM
4drman's Avatar
4drman
Takes more than patience.
Default 92 civic amp wiring?
wow. i hate to be one of them new guys that post questions...:ugh: but... i searched all the posts i could find about wiring the power cable thru the firewall, & im still having problems finding a hole thru my 92 civic sedan firewall
i looked all thru my engine and found zero (0) places i could see a wire might go thru (this was expected seeing as alot of the time u have to make the hole)
i peeled back my carpet on both the driver and passenger sides but only found plastic circle type plugs that are a translucent white plastic color(if that helps)
i removed a couple of them and inspected the holes they led to, i found a sort of rubber sheet blocking it any further. i would go ahead and poke thru it but i cant find where it would go thru to in the engine. and im not trying to stab my battery etc
oh and idk what a grommet is...:-\ heh...
Old Jul 26, 2005 | 05:42 PM
03cbr600f4iguy's Avatar
03cbr600f4iguy
there might be a rubber plug behind the battery on the firewall, and one on the other side, in front of where the guage cluster is, a couple inches down from the top.
Old Aug 3, 2005 | 11:59 PM
4drman's Avatar
4drman
i wired it thru the hood and side panel thru the door. i couldnt find anything i would remov with confidence hah, there was alot of things in the way as well
Old Aug 4, 2005 | 09:50 AM
delsol161's Avatar
delsol161
i have two holes in my del sol. '94. i was told it's an EG1 in that helps. anyway, one is by the brake booster on the driver's side. and the other is slightly below/right of my battery. i used that hold to run the power wire through. it goes in, then straight down (very tightly) till it pops out under my glove box. any help?
Old Aug 4, 2005 | 10:14 PM
orbit77's Avatar
orbit77
don't do it thru the door jam! it can cause a fire and very unsightly looking. there's an grommet to the bottom right of the battery. also another one behind the battery at the bottom, but that requires taking out the battery. if i have free time tomorrow i'll take a picture of where i'm talking of.
Old Aug 6, 2005 | 03:58 PM
topnatchteg's Avatar
topnatchteg
91 Integra Gs Owner And Same Here Ran The Power Cable From The Batter Through The Door Jam But Hid It Under The Carpate And The Jam Plastic Cover Seems To Be Workin Fine For Me Anough Gap Is Their And Looks Pretty Clean Cant Even Tell Its Thier Unless U Trace To Were The Wire Goes From The Battery To The Amp Otha Den Dat Ya I Tryed Lookin Fow An Easy Way To Get It Through The Firewall Just Sayed Hell With It And Saved My Self A Big Headace And I Think You Will To Runin It Through The Door Jam And Under The Carpet If U Wana Make It Look Clean I Have It Runin To The Back Seat Were I Screewd Down My Amp To The Back Of The Rear Seat Totoally No Wires Showin Ran All Under Carpet Cleean Job Well Not Bad Fow Not Havin A Pro Wire It. Hope It Helps
See Ya
Old Aug 18, 2005 | 08:04 AM
icyfingers's Avatar
icyfingers
there's a rubber grommet behind the battery on the firewall, pop it out, cut an x in it, run the wire through, and pop the grommet back in. done.
Old Aug 18, 2005 | 04:46 PM
MPerson's Avatar
MPerson
What I did! Works great
