audio wiring color help
on the stock 04 cd player there should be a wiring diagram, you will need to cut the stereo plugs out of an 04 with enough wire hanging out so you can install it. if you have the plugs what you will need to do is go to your local parts store and buy a stereo harness plug for your year make and model. what you will do is follow the wiring diagram from the stereo and wire nut or sauter each wire from the deck to correct wire on the harness. after you have made all the connections you can plug it in to the stock harness coming out from your dash. turn the key on, if all the connections are made correctly you will have tunes. take your time and follow each wire. if you have an autozone in your town buy your harness there, all the wires are marked with what they do. good luck.
