my backseat.. pics*
Old Apr 5, 2005 | 08:36 PM
Default my backseat.. pics*
the wood holds 2 12" beyma loudspeakers. i have 1 12" alpine type r in the trunk now. figured i share some pics, always wanted to see more of what you guys have in here
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 5, 2005 | 08:43 PM
sherwood's Avatar
sherwood
I missed Sean
it close too?
Old Apr 6, 2005 | 06:51 AM
yeh it does close, theres barley any space inbetween them though. i had to keep moving it back half an inch or so until the amps didnt hit the speakers. the piece of wood is so tight in the space, that i only had to use 4 L brackets to hold it in place
Old Apr 6, 2005 | 10:34 AM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
how does it sound?
Old Apr 6, 2005 | 11:08 AM
the speakers are loudspeakers, so its loud as shit. i dont have any bass coming through them, because of my sub, but before i put the sub in, i had the bass turned up on my HU and they were hitting pretty hard. they are free air speakers, so it was easy to make just a piece of wood for it
Old Apr 6, 2005 | 03:50 PM
97teg's Avatar
97teg
What is the hole in the middle for?
Old Apr 6, 2005 | 04:04 PM
looks h:
Old Apr 6, 2005 | 07:37 PM
97teg's Avatar
97teg
I think i messed something. Your doing an Ib install which uses the trunk area to isolate the back waves from the front but then you cut a hole in pannel so the back waves will no longer be isloated?
Old Apr 7, 2005 | 04:58 AM
na, i didnt plan on isolating back waves at all.. i just needed something to hold the speakers. whats the advantage of isolating the back waves?
Old Apr 7, 2005 | 03:00 PM
97teg's Avatar
97teg
Well in an ib install you are using the trunk basically as a huge box. So you need the trunk to be sealed just like you would any normal box. Or if it sound does get out it does not get back into the cabin because it will cause cancellation that will cause loss of bass, a "thin" sound etc. When a speaker plays it makes one wave that goes foward from the front of the speaker as well as an opposite one that results from the back of the cone. When these two meet they can actually cancel each other out. One of the jobs of the box is to isolate these two waves so you dont get this cancellation. The other result is that the air inside the box acts as a spring. When you go ib typically you also cut power handling of a speaker down a fair amount so you have to be careful how much power you give it. Since your not using them as subs and it looks like it has a relatively stiff suspension its not quite as big of a deal. I guess i dont see the point to using those speakers as full ranges esp when the seat is up and blocking them but if it sounds good to you then might as well go with it. Now seal the trunk off put a pair of 12" subs there and its a different story. Components just not loud enough of what?
