Question
Old Mar 20, 2005 | 11:34 PM
Raun_31's Avatar
Raun_31
Default Question
How can i run 2 amp to subs?
Old Mar 21, 2005 | 06:53 AM
Illegal B16's Avatar
Illegal B16
New Zealand
WHAT? Do you want to run a single amp to a single sub, or two single amps to two seperate subs, or what? If your gonna run 2 amps, first thing is to make sure to have 2 pre amp outputs on the head unit first.
What kind of power wire kit do you have. What guage wire?
Old Mar 21, 2005 | 08:02 AM
b00gers's Avatar
b00gers
You can, but you shouldnt.
If you want to run 2 amps to a sub, you are going to have trouble getting the amps to feed the amp the exact same signals. If you wanted to run 1 amp per sub and have 2 subs, once again, it will be hard getting them to play the exact signals. Stick to 1 amp for your lows.
