can i use a bigger amp??
ok right now, i have 2 12" polk DB's (Dynamic Balances (discontinued)), and a Kenwood KAC-728 powering it...
NOW MY QUESTION IS...is the amp i have right now enough for my subs? or can i go even bigger to make them pound harder? if, i can get a bigger amp, please give me some suggestions...most of the suggestions if have gotten were towards either a JBL 1200.1 or a 600.1 (mostly 600.1)...thanks these are the specs for one 12" sub... 12"(30.5cm) Subwoofer db subwoofer drivers are optimized to deliver explosive bass performance when used in small sealed enclosures. They provide you with deep, tight and musical bass for the true high-end car stereo enthusiast. Ultra stiff mineral filled polymer cones withstand the extreme mechanical stresses generated in sealed enclosures. These are the stiffest, strongest cones you can buy Killer bass from enclosures as small as .9 cubic foot Steel / Polymer laminate basket damps basket resonance for clean, uncolored response Four-layer 2" diameter voice coil and vented pole piece for superior power handling Available in 8 and 4 Ohm versions Cutout Diameter 11" 27.94cm VAS 2.54 ft3 82.31L SD .563 ft2 .0523m2 Winding Width 1" 25.4mm Xmax - Linear .343" 8.7mm Xmax - Mechanical 1" 25.4mm Height of Air Gap .315" 8mm Magnet Assembly Weight 9lb 2oz 4.1kg Magnet Weight 4lb 2oz 1.9kg Vd - Volume of Driver .062 ft3Nominal Impedance 4 Ohm Frequency Response 20 - 200Hz Sensitivity 86dB Power Rating 800 watts Actual Impedance - RE 3.7 Max. Power (RMS) 400 Watts Max. Power (Peak) 800 Watts Resonant Frequency - FS (HZ) 23.6Hz QMS 4.523 QES 0.510 QTS 0.450 Cms 212 BL 15.00 TM Mms 179 g THE SPECS FOR MY KENWOOD KAC-728 AMP ARE: Key Features Maximum Output Power: 600 Watts x 1 Power Ratings Bridged Power Output at 14.4V (1kHz, 0.8% THD): 300 Watts x 1 Maximum Output Power: 600 Watts x 1 Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 150 Watts x 2 Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 100 Watts x 2 Power Supply Features 2-Ohm Stable Black Anodized Top Cover: with Aluminum Heat Sink Plate Copper-Shielded EE Core Transformer Large Secondary Capacitors Large Toroidal Noise Suppression Filter Power Indicator Power Input Terminals: Gold-Plated Power MOSFET Switching Power Supply Audio Features Ground Isolation Circuit Quiet Turn-On RCA Audio Inputs: Gold-Plated Selectable Low-Pass Electronic Crossover Speaker Connectors: Gold-Plated Speaker Level Input Terminals Speaker Relay Protection Stereo, Mono, or Tri-Mode Operation |
The subs are rated at 400 watts RMS and 800 peak, so a JBL BP1200 would be a better fit than the BP600. Also, depending on which ohm subs you have (hopefully the 4 ohm ones), you could look into a Rockford BD1000 which maexes power at 2 ohms. If you have 8 ohm subs, then you'll need something that maxes power at 4 ohms bridged, like a PPI PC2600, RF Punch 800, Phoenix Gold ZX600ti, etc....
SiClone is right, it depends on the subs you have and thier ohm load.
What is your budget for a new amp? |
