Crappy radio reception
Old Feb 1, 2005 | 04:59 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
Default Crappy radio reception
I lived many years with the OEM radio so I know the potential reception. Then I buy a Panasonic deck with the stock antenna and the FM and AM reception is worse.
What can I do to improve reception? And is this a problem with Panasonics?
Old Feb 5, 2005 | 09:43 PM
Brar's Avatar
Brar
ummmmm is ur ant going up when ur deck is on? just to make sure ur ant wire is plugged into the deck right? otherwise umm i guess it is the deck
Old Feb 8, 2005 | 08:08 AM
ISP James's Avatar
ISP James
DAMIMRED
:no:
some decks have stronger or weaker radio signal "amplification" usually, when you buy a deck, if you are buying from a guide (or not, check the box) it will tell you how powerful the radio is for both AM and FM. chances are, your decks forte is not radio signal :happysad:
