Whirring noise from Civic dashboard
Old 08-14-2004, 12:35 AM
rincewind
rincewind's Avatar
Default Whirring noise from Civic dashboard
Hi, this is going to sound like a thousand posts that have come before (ie the old "my new car stereo whines.. what's wrong?! "incorrect grounding.. etc etc"), but it's not.
I just had a new stereo installed. I now have a strange whirring noise that seems to come from directly behind the a/c and temp controls. It happens when the revs go over about .. well i I don't know cos I don't have a tacho (It's an 96 Aussie CXi model), but I'd say whenever I rev high enough to need to change gears.. so probably between 2 and 5 thou?..
This sound happens without the face plate on (eg no signal to speakers etc). Now, I figured there may still be some kind of noise produced by the head unit (e.g. to do with wiring... clutching at straws here), so I diconnected the positive terminal from the battery to the stereo setup. So now I think I can safely say that if the sound happens, it's not made by the stereo right?
Well, I still get the sound. The fact that the sound originates from behind the dash instead of any of the speakers makes me suspect the audio install guy has given something a knock.. or possibly not connected up something properly..
Do you guys know what this sound might be? What A/C connections (or anything else ) are there behind the dash that could make a buzzing sound that is very obviously dependant on engine speed?
Everything sounds fine from the engine bay (have had others listen too, just to check).
Thanks in advance.
Old 08-14-2004, 07:15 PM
rincewind
rincewind's Avatar
Have now also checked the hole in the firewall through which the power comes. The grommet was pretty shabbily done, so replaced it with a tighter one. No difference. Also plugged up completely with blue tac just to be sure. No difference.
Still searching..
